Two questions for you (at end of post):
Background:
I've got a system to design as part of my work (medical imaging - archiving to DVD), unfortunately it has a number of constraints:
1) Automatically trigger multi-session real-time capture from s-video source. This will be done by remote control so *no manual editing or intervention whatsoever* - i.e. no GUI MMI. I don't need to see the video in real time - just capture.
2) Low-spec PC motherboard (therefore HW MPEG capture? - yes, I know I could get better quality from software compression).
3) Automatic transfer to DVD (for playback on standard off-the-shelf players).
Current system: Duron 1600, 256MB RAM, 7200rpm HD, AverMedia EZMaker Gold PCI (SA7134 Chipset), SuSE Linux 8.2. I'm also a newbie to DVD so any pointers as to what I might be doing right or wrong would be a very great help!
Here are my two questions:
A) so far I've used ffmpeg to capture, - can I configure ffmpeg (or other recommended software/commands?) to capture to HD or DVD directly from the HW compressed PCI card output?
B) i've read that the SA7134 chipset requires an updated kernel (2.4.23+) and patches and modules. I don't believe my new install of SuSE 8.2 has any of these, but my capture card appears to work on XawTV, KVDR, etc. Why? Am I missing something and would I get better performance by updating?
Any other comments or advice would be very greatly appreciated.
Thanks, GB.
Results 1 to 1 of 1
multi session
By didikai in forum Off topicReplies: 0Last Post: 28th May 2010, 05:44 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 05:03 -
Best "Multi session" DVD Image ??
By Anurag in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2009, 01:22 -
Verbatim DVD-Rs won't multi-session, it always finalizes.
By Stealth3si in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 08:26 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 23:16
