Could a DVD ROM cause problems with a DVD Writer on the same IDE cable? Until a few minutes ago I wouldn't have thought so, but it appears I may be wrong.
I've had problems on and off with my DVD ROM- it had a hard time reading CDs, and recently it's had trouble reading DVDs. Sometimes it would read 3-4 in a row with no problem, other times I'd have to remove and reinsert the same one 2-3 reads before it would read it.
A week or so ago I started having problems with burning. I kept getting an error code with something about a Sense Error. I tried everything from a clean install of my hard drive to getting 2 new DVD burners. Nothing worked. Today moved my burner, DVD ROM and one hard drive to another computer. The first DVD I burned gave me the same error I've been getting for days now. I was ready to throw both computer out the window and tried to figure out what could cause the same error in both systems. I knew it wasn't a bad burner and I'm pretty sure it's not a problem with the hard drive. That left the DVD ROM as the only common factor.
So I unplugged the DVD ROM and tried to burn a disk- it worked. I won't be convinced until I burn at least 8-9 without errors, but I can't think of anything else that could be causing the problem so I'm hopeful.
So, is it possible for a slave device to cause problems like that for the master device on the same IDE?
Even stranger- part of that time the DVD ROM was on a different IDE- the writer was the master connected to the motherboard, the ROM was the master connected to a controller card- but there problems were still there.
Results 1 to 1 of 1
How long should a DVD burner last?
By Regor21 in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Sep 2010, 14:31 -
DVD burner problems
By coody in forum DVD RippingReplies: 5Last Post: 12th Sep 2008, 01:18 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 10:46 -
Problems with DVD Burner
By poppy56 in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jan 2008, 23:48 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
