Hey folks,
I'm using DVD Architect and I was just wondering if there was any way to insert a short clip before the main menu in a DVD project I'm working on. I want the clip to be the "first played" item on the DVD so that it plays first and then the menu is displayed. Any help would be great. Thanx very much!
Idioteque74
Yes, you can.
Goto File. Properties. And under the General tab you will see Introduction media. One for video/image and one for Audio. If the mpg is both just put the file in both. And if you want the same video in every project you create check the box that says "Start all new projects with these settings". -
Wow...who would have thought it would be that easy. Thanks very much for the help, it is greatly appreciated.Originally Posted by scottvf
Idioteque74
Blu-ray PopUp Menu with DVD Architect Pro 5.2?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 03:02 -
DVD Architect Pro 5.0 - Problem with Menu launch
By stealers in forum Authoring (DVD)Replies: 0Last Post: 3rd Jan 2009, 11:36 -
automatic chapters menu in DVD Architect
By exon in forum Authoring (DVD)Replies: 0Last Post: 18th Aug 2008, 10:10 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51 -
Software suggestions for video clip or motion menu at the beginning of DVD?
By hitman3000 in forum Authoring (DVD)Replies: 2Last Post: 14th Mar 2008, 20:30
