  1. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I'm getting a error msg when trying to use VirtualDub.
    "Couldn't locate decompressor for format "dvsd" (unknown)
    VirtualDub requires a Video for Windows(VFW) compatibile codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable".
    Can anyone tell me what codec do I need to use this tool? I would appreciate any help. Thanks in advance.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Thanks rcb it worked!
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I used afonics guide to join avi files together using virtualdub but I got a runtime error. I'm testing to see if I can join 6 avi files together. Anyone ever joined more than 2 avi files together using virtualdub? Thanks in advance.
