Hey all. I have a fresh install of Windows XP w/SP1. What is the best driver combo for this card. Catalyst, WDM, MMC. I figure the catalyst drivers have nothing to do with capturing. However, I see LordSmurf uses MMC 8.1. What WDM drivers do you all use? Lastest, the one that came with MMC 8.1, which? How about the control panel? I'm using an AIW 8500dv. Thanks for your help.
I use both 8.1 and 8.7 ... for drivers, I use stuff from early 2003 ... no need to upgrade for me.
I'd use newest drivers and then ATI MMC 8.1 to 8.7 ... not 8.8Want my help? Ask here! (not via PM!)
In my last system I ran an 8500DV and liked MMC 8.6 full set. (cat and wdm). These are available at ATI. I tried most every version and that one gave me the lowest CPU usage and the most consistant AVI capture framerate.
On this system I'm running v8.5 and it's the only version of mmc I can remember that gives me 720x480 avi capture settings. 704 was all I could ever select before and for 720 I had to edit the registry, but 8.5 has given me 720 as an option. Yea..... And the AVI framerate is solid on 29.970 everytime in MMC.
Good luck.
hd600 won't install w/ pre-existing Catalyst 10.4 drivers
By leslie80 in forum Capturing and VCRReplies: 7Last Post: 4th Jun 2011, 17:14 -
Question about the Diamond ATI TV Wonder HD 650 Combo PCI-E
By usually_quiet in forum Capturing and VCRReplies: 4Last Post: 24th Feb 2010, 13:24 -
ATI driver install + FIREWALL = TROUBLES
By hypercube in forum Newbie / General discussionsReplies: 6Last Post: 13th Feb 2008, 11:47 -
ATI Promises ~80% Speed Boost with New Vid Drivers
By Soopafresh in forum ComputerReplies: 0Last Post: 17th Oct 2007, 15:26 -
Problems installing AIW drivers
By Ddanrr in forum Capturing and VCRReplies: 3Last Post: 10th Oct 2007, 21:14
