Results 1 to 9 of 9
    Montreal, Quebec, Canada
    I've been a DVDShrink fan since the beginning, and loved 3beta5, but recently had a problem with 3.1.4. I open the disk and deep analysis says it's going to take 11 hours to do its thing. I cancel deep analysis and try to transcode. It also wants to take 10+ hours. I open 3beta5 which I still have on my machine and it says it will take less than 50 minutes for the same movie. I've tried 2 different movies with the same result. Do I have to uninstall 3beta5 for 3.1.4 to work properly? Any ideas welcome.
    Morloc
  2. Member wulf109's Avatar
    Jul 2002
    Odd,I'm not a fan of DVD Shrink but I find 3.1.4 to be faster than 3.0. I doubt un-intalling will help because 3.0 doesn't use use an installer.
    In 3.1.4 in preferences did you check "run analysis in babckground"?
    It's should be checked by default.
    Thanks for the suggestion, Wulf, but I already had "run analysis in background" checked. Other settings look OK too. I'm stumped!
    Morloc
  4. 11 hours sounds like more serious problems than a revision change - I don't use DVD Shrink often, but I think the longest even a deep analysis has taken from an encrypted disc was probably no more than about 45 minutes... are your drives set to (U)DMA and not PIO for example ?
  5. One small thought--what's your box look like--processor, memory, hard drive(s)?
    A kiss on the hand might be quite continental, but tactical nukes are a boy's best friend
  6. Originally Posted by Morloc
    Morloc
    Do you mean unchecked? Having it checked would make it take longer right?
    Blah, blah, blah
    No I had it checked. I'll uncheck it, but I don't think that's the problem. I've also been reading the posts on the DVDShrink.info site, and I'm not the only one with this problem. It seems there is a conflict with Nero 6, and when you uncheck the "burn with Nero" option, it has solved the problem for some people. Not for me however, I use Nero 5 and unchecking that option made no improvement, so I'll probably continue to use 3beta5 until the next release comes out.
    Thanks to all who tried to help.
    Morloc
  8. garryheather asked a pertinent question:
    are all your drives including the dvd rom set to DMA?
    Sorry, for got to answer that.
    Yes, all drives and both my DVD drives are set to DMA.
    Morloc
