I need good decent media for the 811s I had 2 dvd-r types the cheap ones and I'm skipping around like not even funny
andyone now of decently priced media that is not totally junk. cheap seems not the way to go here. since this burner doesn't support 1x dvd-r burning
help
terramir
PS it looks like my last post disappeared![]()
Results 1 to 10 of 10
added videocard had to downclock my proc got 10 C hotter in my case time to ducts that sucker ;@ had to down my overclock was 2200mhz now 2100 mhz :'(
Please guys a little help for a newbie here
terramiradded videocard had to downclock my proc got 10 C hotter in my case time to ducts that sucker ;@ had to down my overclock was 2200mhz now 2100 mhz :'( -
Memorex 4X + burns at 8X with the proper firmware and can be read in most/all dvd players.
hope this helps -
Better say "most" - they don't play in mine, but then they are usually made by CMC and that explains a lot...
Ricoh 4X +R discs burn at 8X in my 811S and, using the bitsetting utility, are burned as DVD-ROM discs. This booktype allows them to be played on older players.
the memorex i have been getting is the good richo stuff!!!!!!!!!
what about -r media because I dun have that much money and 240 gb worth of harddrive space to back-up
yaeh I could condence the stuff and I would still have like 120 gb worth of files left from all my downloads to what ever!
-r media plays in more players too
so what yopu guys say which media will burn in my dvd-r +r recorder with the greatest compatablillity and still be at a decent price
Originally Posted by terramir
If you want -R's, I'd go with Grade "A" Riteks. -
I would recommend the following. I have used all in my 811s with success.
Fuji DVD-R 4x media buy only the box marked Japan
Taiyo Yuden media will burn at 4x in 811s
Maxell DVD-R media in 15 pack at Office Depot for $26 made in Japan only
Hitachi/Maxell media will burn at 4x in 811s
Verbatin Datalife Plus DVD+R 4x 15 pack at Office Depot $34 made in Singapore only.
Mitsubishi Chemical made media. will burn at 8x in 811s
The RICOH JPNR01-002 DVD+R 4x media sold under the brands of TDK, Memorex and SONY work and will burn at 8x, but I have more errors with this media than the Verbatim listed above. A friend with a 451s also has problems with this media.
I am still trying to buy some certified RITEK 8x DVD+R media, but the two vendors I have bought it from sent the the 4x certified RICOH. Either RITEK or these vendors or both are trying to unload slower media on the US market for a premium price.
If you see RITEK certified 8x media for sale in the US most likely it IS NOT RITEK but RICOH which is made by RITEK under contract. IT is not the same media and you DO NOT want to pay the premium prices they are charging for it.
I hope this helps. -
does help thx
the memorex +r media is great I just burned several DVD's not a coster yet duh it's ricoh media
got it really cheap as a subtitution at officemax :P
I need help finding a good video editing software at a decent price.
By JoryWLU in forum EditingReplies: 1Last Post: 27th Jan 2011, 23:18 -
Converting AVCHD Lite for editing in Vegas10 and then to a good format.
By Domiel in forum EditingReplies: 11Last Post: 24th Nov 2010, 09:11 -
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 01:47 -
lite-on 165p6s, slow copy, good burning?
By troy512 in forum DVD & Blu-ray WritersReplies: 3Last Post: 23rd Oct 2007, 09:13 -
vLite - Vista Lite ANy Good
By mn072065 in forum ComputerReplies: 4Last Post: 19th Jul 2007, 16:37
