  1. I found this tools on http://www.poikosoft.com and was wondering if anyone has heard of it or used it before. Does any know if the audio extraction quality is any good and is it better than nero burning rom 6.3 for audio extraction?
    In nero and this program, they both say u can download cd-text information for an audio cd (such as artist name, track name etc) from freedb.freedb.org, i was wondering if u need to download any additional software or can u just vist the site, search for the cd-text and then manually type it in. And last thing, you can download a CD ID, what is this?
  2. Member wulf109's Avatar
    Jul 2002
    Easy CDDA Extractor is the BEST audio ripping program money can buy. It will download disk info as long as your connected to the net.
    Money well spent. Just my opinion,I've used it for years.
  3. Member Sakuya's Avatar
    Dec 2002
    But there is a free program called DBPoweramp that can convert media files as well as CD-ripping. I've only used the CD-ripper once but it works pretty well I should say.
    Feb 2002
    Toronto, Ontario, Canada
    CD-DA Extractor is a beautiful application. Easy to use and all around wonderful. It's my ripper of choice.
