I have an ATI AIW Radeon with composite and S-video Inputs. Also a sony Digital8 camera, with s-video, composite,usb and Dv outputs. I dont have the PC right now, its being repared. So what would be the better way to capture my videos. s-video capture to make an MPG-2, or use the USB to tranfer it? (i don't have firewire card to capture it from the DV output digitaly). But, the USB will transfer it digitaly, or will it be "captured"? I have got good quality making "Capture" with s-video, directly to dvd format. Ive read that DV makes transfer, not capture, so it gives better quality. If its worth, ill buy a card.
i would suggest getting a firewire card and do a transfer ..
Originally Posted by BJ_M
That would be the best way. As for using USB, I have had terrible results using USB 2.0 for video.
SLICK RICKOriginally Posted by lordsmurf
is there a USB device to watch live composite video ?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2011, 08:56 -
EZcap USB (composite) VS Blackmagic VIDEO RECORDER (component)
By wagz82 in forum MacReplies: 5Last Post: 15th Sep 2010, 20:14 -
Capture from DVI or Composite
By bb69 in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2009, 10:37 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 08:09
