Hello all,
My Pioneer 343 played pal svcd's with no problem until a had a region hack made to it. Now the pioneer intro screen and menus are in black and white as well as svcd's. My tv cannot take the NTSC signal that the player seems to be sending out. I gather that since the 343 cannot send out the raw rgb signal, then a non-ntsc tv cannot be made to work with any combination of cables.
Any advice?. Should I revert to the original firmware and dump my region 1 movies, I will prioritize svcd's in pal to ntsc region 1 movies.
Anders
try switching your player from auto to pal
if not , go and buy a multi system tv
tommy -
Thanks,
You should have said RTFM (Read The ******* Manual).
It said quite clearly what to do, and I did not look until now. Both my svcd's and my region 1 movies work just fine.
My only excuse is that it working before the region hack, but this setting must have been erased with the upgrade.
Thanks for the advice.
Anders
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
black and white
By foofie131 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 22:15 -
Screen turn black when my Pioneer DVR-330 plays my homemade DVD-video
By dcmwong in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Dec 2007, 13:58 -
By dcmwong in forum Authoring (DVD)Replies: 1Last Post: 6th Dec 2007, 10:58 -
Video Plays Washed/too white
By carlitos287 in forum Software PlayingReplies: 4Last Post: 30th Oct 2007, 14:23
