I converted a DVD to a DivX file. When I try playing it in Window Media Player 9.0 it mentions in the status bar - looking for codec and then errors out saying cannot play the file. I tried it with BSPlayer too. I have the code DivX Codec 4.12 installed. What am I missing?
I used FairUse 0.35 to do the conversion to DivX.
When I conver to XVid the file is playable both in the WMP and BSPlayer. I wanted to find out if XVid was better or DivX.
Issue resolved. I went to the advanced options of FairUse 0.35 and found that the codec expected was DivX 5.1.1 - so downloaded the this codec from Divx.com and I can now play the files.
I couldn't however decide whether XVid was better quality or the DiVX file. I converted the same dvd with the exact same audio bit rate and file size.
Convert DVD into DIVX / XVID using FairUse
By p_uriel in forum Video ConversionReplies: 1Last Post: 19th Jan 2011, 16:26 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 14:45 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 19:00 -
WMP doesn't play hyperlinks directly
By jemoto in forum Software PlayingReplies: 4Last Post: 15th Mar 2008, 23:37 -
Panasonic DMR-EH56 doesn't play 2nd audiotrack of DIVX-file
By Scotty73 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2007, 11:27
