  1. Hi everyone -
    I have a slew of OGM files in need of conversion to VCD. I found a very helpful tutorial that describes how to convert OGM to SVCD, part of which involves the use of TMPGENC. It was through this tutorial that I learned that as long as you have all of the plugins et al for OGM, TMPGENC will convert OGM files to mpg.
    My question is this: if I am just going for VCD, is there any reason I can't just open the OGM file, audio and everything, in TMPGENC and convert right to VCD-compliant mpg? The only drawback I can see is that I am stuck with the DivX watermark on my video - any suggestions on how to get rid of this?
    Thanks -
    Brian mc
    Mar 2003
    Uranus
    Post a frame with the watermark.
    There are several ways
  3. Do you know how I can capture a frame using "The Core" media player?
    Thanks for your help -
    brian mc
  4. Actually, after taking a closer look, the DivX watermark fades out after about ten seconds. I suppose this is ok, but I don't know if it would behave the same way when converted to mpg. Have you heard of this before?
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    You can disable the DivX watermark.
    Go to
    Start-->Programs--DivX-->DivX Codec-->DivX Configuration Utility.
    From the application that starts, go to Quality Settings and there, check the option named isable Logo.
    The more I learn, the more I come to realize how little it is I know.
