As a favour to those that are less BBCode inclined on the forum I have made up this simple guide on how to quote others in threads.
Firstly there is a 'simple quote' and looks something like this when posted:
To make a quote like this just follow these simple steps.I like Apples!
1) Copy and paste the text that you wish to quote into your own post. Alternatively you can type out the text instead of the copy/pasting.
2) Highlight your text and then click the "Quote" button located below the "Subject" line field. This will then add BBCode 'tags' around the text and will look something like this:
Alternatively, you can manually type out the quote tags yourself. Remember though that the 'close tag' will require a / before the word quote.Code:I like Apples!
We now move on to the second type of quote, the 'advanced' quote. The difference between it and the 'simple quote' is that it displays the Username wrote: phrase instead of the normal Quote:. If done correctly it will look something like this:
To make a quote that looks like the above example follow either of these two methods.Originally Posted by pacmania_2001
Method A:
1) Click the Quote that appears above the post that you want to quote from. This is the button that appears next to the other buttons like Computer Specs, Profile, PM and Email.
That's all the steps that are required for method A
Method B:
2) Highlight your text and then click the "Quote" button located below the "Subject" line field. Alternatively, you can manually type out the quote tags yourself. Remember though that the 'close tag' will require a / before the word quote.
3) Right now your code will look similar to this:
It's time to personalise it with the username or phrase you want. To do this we must edit the first or opening quote 'tag' Here's an example:Code:I like Apples!
If this were posted the phrase, pacmania_2001 wrote: would then appear before the quote itself. As you can see all it requires is the following to be added to the first quote tag, ="Username"Code:[quote="pacmania_2001"]
It's that simple! Now you have no excuse as to why you, yourself can't quote in the comfort of your own home.
Title credit goes to tgpo. Guide coming out on DVD/VHS to a store near you in the Summer
Results 1 to 20 of 20
I can't get the highlight and click the quote button to work. I've never heard of it working like that before either. Am I missing something?
Might be browser dependant?
I'm using IE6 and never had a problem with it or with any version of IE before it. -
I tried it again and can't get it to work using Safari. I'll give IE a quick try.
Nope. IE won't do it either. It simplay adds the quote tag at the end of the text as usual.
Weird. Is that IE on a mac, or windows?
Maybe I some how downloaded a special version of IE. -
Mac. I'll give the PC version a quick try.Originally Posted by pacmania_2001
Strange. I'm on the PC now and it did just as you said, but on the Mac it just adds it to the end of the text. So I guess it depends on what OS you are on.Mac. I'll give the PC version a quick try.
But don't click any links if you own one and use IEOriginally Posted by pacmania_2001
Just have some common sense, that's the best security. It amazes me how little some people have of it these days.Originally Posted by tgpo
Brilliant guide, Pac. - well laid out and very easy to follow.
but you can stick your quoting up your arse
I refuse to quote another user until the moderators admit to tampering with my account (they're upto somink I just know it).
one minute I got 6000 posts, then i'm down to 325, and now all this trouble with the quotes.
something fishy going on here...I feel like Harrison Ford in The Fugitive
Well I do admit to tampering with one of your posts in "the specialist list" to fix up one of your unsucessful quoting attempts. -
Talk about fine print:
Originally Posted by pacmania_2001Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Betamax and Laserdisk will follow later
But if anyone wants it early, Caridi just gave me a screener of it. -
Be Careful, that could be considered warez and get you a yellow cardOriginally Posted by tgpo
I knew I shouldn't have trusted that bastard.Originally Posted by tgpo
Now if only I had my own team of lawyers and lobbyists I might stand a chance of enforcing my copyright.
SIMA Stabilizers -- The Definitive Thread
By Anonymous4 in forum RestorationReplies: 21Last Post: 8th Jun 2009, 21:27 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 14:29 -
Does quoting someone else's post use bandwidth?
By moviebuff2 in forum ComputerReplies: 5Last Post: 15th Jan 2008, 21:16 -
The definitive guide to the total nube!
By stevezygote in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 17:02 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 08:03
