Due to ongoing conflicts with Windows XP I am looking for a new anti virus program. Could anyone possibly provide feedback on the AVG program? Have you experienced any conflicts with Win. XP, is it dependable, do you like it, does it work properly, good customer support, etc. Thank you so much for your reply.![]()
Thank You,
GolfNut -
noOriginally Posted by golfnut
yes
yes
yes
no idea
my pleasure
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Thanks guys, I really appreciate the feedback, I think I will give it a try, what the heck, like you say, its free.
Thank You,
GolfNut -
I did have problems with Norton AV on a WinXP computer.
Conflicts and serious software damage did occur in the OS. This was on networking and Internet access configurations and the only way was to re-format and re-install the OS.
This depends on what you do, how and what you add in the system. These are the hints. This is just any example, don't install NAV2002 then uninstall the re-install the older version NAV2001. Don't use Microsoft's firewall with NAV together as well. Mixing of AV and firewall brands is out.
Best to use one brand only at a time in order of versions and switch off Microsoft’s firewall. This is only a guide and someone’s computer maybe ok.
I recently was having problems with NIS and a change to AVG advisable.
Do you use Norton anti-virus or freeware of something else?
By beavereater in forum ComputerReplies: 26Last Post: 31st Jan 2011, 23:34 -
AVG Virus warning on this Website
By wulf109 in forum FeedbackReplies: 59Last Post: 20th Jun 2010, 12:16 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 22:28 -
AVG Anti-Virus deletes Goldwave software
By lordsmurf in forum AudioReplies: 9Last Post: 22nd Sep 2008, 08:55 -
Norton Anti-Virus: I Think I Have Been Shafted
By Tom Saurus in forum ComputerReplies: 27Last Post: 21st May 2008, 19:11
