I've used TMPGEnc to convert the AVI/xvid to mpeg1, but when I do this it will not take the audio portion, so i used VirtualDub and avi2wav to exact the wav file (which was sucessful) but TMPGEnc still would NOT take the wav file from this xvid..........really frustrating...does anyone know what I can do or maybe another audio exacting program is can use? it says the audio is ac3 (0x2000).
First, get an AC3 filter.
See if you still have the same problem, because TMPGEnc should do the audio at the same time as video, without having to separate, then rejoin them.Cheers, Jim
My DVDLab Guides -
TmpGenc will not convert Ac3 to anything.
Several solutions.
1) Use Headac3he to convert the Ac3 to wav or mp2.
2) Load the avi file into goldwave and save as wav (needs the Ac3filter installed 1st)
3) Load the Ac3 into BeSweet and convert to wav or mp2
4) If making a DVD, use the Ac3 file as is, just dont load it into tmpgenc but do load it into your authoring program along with the video.
Convert avi in xvid to mpeg with subtitle
By mrweisslee in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2009, 02:46 -
convert XviD to DVD format but lost audio track 2
By zenghe in forum Video ConversionReplies: 2Last Post: 3rd Mar 2009, 16:34 -
convert 2 audio track xvid file to ipod 3g
By felix in forum Video ConversionReplies: 1Last Post: 8th Oct 2008, 14:45 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 18:45
