Hi all, I have a easy question “I hope”
I am looking to burn AVI files to DVD, do I need to convert the AVI to DVD first or will Nero do it automatically for me when I burn the file DVD??
Thanks Targetboy
You need to convert first and then burn with something like nero. Go to the convert section and from the drop down menu select avi to dvd.
Thank you hardcoreruss for the link,
WOW it looks more difficult then I thought, is there any software out there that will do it all for me??
In theory Nero can do it, but that's just in theory. The same goes for every application that claims to be able create a Video DVD from any AVI source.
The AVI format is simply too loose, and can contain almost any kind and combination of audio and video formats.
/Mats -
I see, in your opinion what tools would you use from start to finish,
Start = AVI movie
Finish = Burned DVD “that plays lol”
Thanks again
Targetboy -
VirtualDub to check the AVI, resize it (see frame serving), and if needed extract the audio (if it's not already in a shape A) suitable for DVD (see WHAT IS -> DVD top left)) or B) in a format your encoder can't read).
Audio conversion software xyz to wav, where xyz is the format of the audio track in the AVI.
An encoder - TMPGEnc or other (MainConcept, CCE ...)
Authoring software - IfoEdit, TMPGEnc DVD Author...
DVD ISO creator - imgtools classic
DVD ISO writer - DVDDecrypter
/Mats
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
