Hi anyone help me please< i have an external USB2.0 Closure witha Pioneer 106 inside, I am using Toast Titanium 6.0
The problem i am having is that an error occurs whilst starting to copy my dvd copy onto a dvd-r
The error Buffer Underun appears on ever attempt (10 )
I have been into the recorder settings under the advanced modde but it will not let me check with a tick the buffer underrun section
Hope you can help thanks..
Also will my Emac play multi region dvd s as I have a box appearing saying to set it up for region but can only be set up 5 times
Help pleeeeeeeeeeeeeeeease
Results 1 to 12 of 12
What speed are you burning at?
Have you tried to burn slower?
Are you using quality media?
Is the drive USB 2.0 or USB 2.0 Fast? -
Hi Mate thanks
i am writing at 1x speed and its just a USB2.0 as far as i know?
they are white label dvd-r with purple colour write side and they are green coloured top thanks -
Hi Mate
It just says whitelabel-media.com
how do i know if this is usb2.0 mate
sorry to be a pain -
Typically USB devices are either 2.0 or 2.0 Fast. The fast version has speeds as fast as firewire, while the 2.0 has speed as fast as a snail. I would hope that the drive is 2.0 Fast, but if you're on an eMac, I dunno if they had 2.0 Fast ports. Anyone know if they did or not?Originally Posted by pryddie
Have you tried different media in the drive? Perhaps try an Apple or Verbatim disk and see if it works with it.
Are the files on your Internal HD or are they on an external? -
Hi mate
Thanks for your patience, what i do have is this, a copy(backup) dvd-r in my dvd rom in my emac and my blank disc obviously in my external dvdrw so im trying to copy the disc
hope this helps mate
thanks -
Emacs only have USB 1.1 ports, which move data at 120mbps.Originally Posted by tgpo
We have six at work, four are Emac 700, one is an Emac 800,
and the last one, we got three weeks ago, is an Emac 1GHZ.
All are USB 1.1 ports.
To fix your problem, you'd be better off returning the external case,
and getting a USB/FW combo external case, that way you can burn via FW, and knockout your BU problems.
I do what you do ( Source DVD in the emac DVDRom drive, Blank in
the FW attached external burner) and only FW spools the data
fast enough to avoid the BUruns. Try to match the read speed
and the burn speed minus one to help further, ie. if your
DVDROm reads at 24x and your burner burns at 4x, a 2x burn
will help mimize BU runs.
Of course, nothing beats burning data direct from HD 2 DVD-R..... -
How much memory you got?!
Bufferunderruns can come from not enough memory!
also from the data being chocked up as it goes from computer to external recorder! -
Do what Terryj says. Your USB ports are too slow for burning DVD regardless of what the drive or case say is possible. You must connect your drive via firewire.
What a bunch of Weasels!!Originally Posted by tgpo
When the heck did they do that??
I know there's no point in asking Why they did it.
Mike"Dare to be Stupid!" - Wierd Al Yankovic
DVD Flick Run-Time Error 13
By amrcnbut in forum Video ConversionReplies: 2Last Post: 28th May 2011, 15:50 -
Getting an error when trying to run BD_Rebuilder
By bohdank in forum Blu-ray RippingReplies: 8Last Post: 11th Mar 2011, 07:11 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 14:37 -
vidinomo_PC.cpp error while trying to run starcraft on my new laptop
By econtrerasguzman in forum ComputerReplies: 11Last Post: 6th Sep 2008, 01:14 -
Rebuilder Run-time error ‘52’
By coody in forum DVD RippingReplies: 2Last Post: 4th Jan 2008, 11:03
