  1. Could someone help me on following question or similar case:
    i use shirnk to compress a dvd down to 4.7GB and it's good inside pc but when I burn it by Nero 6.0.3x then simulation failed! The error log says a bunch of things but near the end I see a "write error" blah blah...
    - is it possible of incorrect hardware setting? (spindown, idle, DMA...)
    - what driver nero should have (i installed many other copy software after nero, they may well took away nero's driver...)
    - or something else that you sometimes see in your Sony?
    thank you very much
  2. has the burner ever worked ?, video only ?, does data work ?
    If it's wet, drink it
    My DVD Collection
  3. yes, i burn lots of times even dvd but sometimes it doesn't work ... I think
