I want to make a screen capture of a fram from a dvd to make a label for the dvd. When I freeze the video and hit the Print Screen button then paste it to a picture program I get the image of the player with a black screen ?
thanks
As discussed here only a couple of days ago in another thread, you probably need to use the capture function on your software DVD player - most usually use an overlay system to display the video which is not capturable in the way you describe. For example, PowerDVD has a button on the control panel with a picture of a camera on it that rather gives its function away.
Good luck. -
It does, and it works well too. But don't forget to go into PowerDVD config->advanced and set it up to capture to file. It defaults to Clipboard otherwise and you will never find them!!Originally Posted by garryheather
(Yes, I did make this mistake
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Video screen capture
By cottage in forum Capturing and VCRReplies: 5Last Post: 9th Dec 2010, 16:37 -
Best video/screen capture software
By latr0486 in forum Video Streaming DownloadingReplies: 2Last Post: 27th May 2009, 17:58 -
How do I do a Screen Capture from a U-Tube video
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2008, 17:34 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 06:08
