Anybody buy these from newegg before?
http://www.newegg.com/app/ViewProductDesc.asp?description=17-132-315&catalog=71&manufa...pa=0§ion=1
$49 and free shipping for 50 ritek discs sounds too good to be true.
I know these are OEM discs, but what does that mean? Are they crap? Are they good? Are they factory rejects or grade q or something?
I have always bought OEM pieces for my computer (who needs the box, or drivers, or manual).. But never OEM media
I am currently down to my last 10 TDK 4x +R's RicohJPNR's, jewel cased for $1.20 each (I should have bought the entire store of them, they are awesome) but they are back up to over $2.40/each
Results 1 to 27 of 27
Hey i bought these and am receiving them today. I will let you knoe how they burn. I will check them on my Plextor 708A,LiteOn 811S, Pioneer A06, and the NEC2500. I will let you know how they burn.
MAX -
In this case, OEM probably means totally unbranded. But brand alone does not a disc make... if they are genuine Ritek's I'm sure you will be happy with them.
Yeah i've been recently looking at the same ritek discs from newegg and plan on buying that 50 pack soon.From what i've heard they are of high quality.
Does anyone know about these ones?
DRD-47-4X-RD-IW
They are the ones right below the ones the previous poster linked to. They are $52.99 for 50. The one comment says they are printable. Can anyone verify that these are printable? Seems like a good deal if they are. -
Those are the ones I use. RITEK G04 . So far 1 coaster out of 130 burns, which is about as good as it gets. 12/12 on verifying after burning.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I just got a 50 pack of these from Newegg yesterday with my new NEC ND-2500A.
They were on sale for $46.50, when I ordered. So far they work great with my drive. They are Ridata brand G04 (confirmed by media code) with purple dye. I haven't had a single bad disk yet.
One note, you do need to have an empty spindle, because this 50 pack doesnt come with a spindle case, it's just DVDs only in shrinkwrap. -
I think you just answered the main question that titio13kfm was askingOriginally Posted by manco
"I know these are OEM discs, but what does that mean? Are they crap? Are they good? Are they factory rejects or grade q or something?
I have always bought OEM pieces for my computer (who needs the box, or drivers, or manual).. But never OEM media"
The OEM to by best knowledge (for what its worth) would mean no spindle just the pack of DVD's (to save on costs of course)
Maybe others who have bought these can confirm...
I always buy my hardware from newegg & if these are infact the real Riteks (with the RiData label & Matte finish) I will probably buy my DVD's from there also. I've had great success w/ Newegg & would love to continue to support a company that is as good as them. -
HI,
I just also purchased a 50 pack also from New Egg. I hope they are the true Go4's.
I got my others from meritline and they been great to me. I used 75 pcs of the G04's from meritline and none failed. I just wanted to try NewEgg ones since they are about $5.00 cheapers or so. I just prey they are the true Ritek Go4's
8)*New Mac user*, been PC user 4 life -
I too have got mine from Meritline b4 but have not had good luck w/ my newest batch of 50... They do not have the RiData label or the Matte finish... I burned 11 disks and have 11 new coasters... The first batch I got from them worked great... time to see how thier customer service is.. they claim 100% satisfaction w/ the G04'sOriginally Posted by Regal
Bucs,
Thats sounds bad man. I am sure meritline will take care of you.
I have not ever bought the 50 pack from meritline. I always purchased to 25pack (3 times - I ordered from them) and not 1 ever was a coaster.
Now my coasters are lookng like memorex CmCs. lol*New Mac user*, been PC user 4 life -
What did you get when you purchased though... did you get the ones w/ the Ridata logo printed in the middle of the disk??? & what did the finish look like??? The ones I got this time that don't work so not have the logo & are just a plain shiny finish... The pack I got the first time was only a 25 pack in just plastic no spindleOriginally Posted by Regal
BUCS,
The top finish was the shiny chrome look.
the 25 pks I got were on a spindle.
I can read one for you right now. Here is the dvd info:
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID RITEKG04
Format Type UDF 1.02
Volume Name D
Application id
Implementation id VSO Software
Recording Date/Time (mm/dd/yyyy) 1/22/2004 21:46:00
Format Capacity 3.23GB(3.46GB)
Book Type DVD-R
Media Type DVD-R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.0x 2770KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 08
2x Speed OPC power 12
2x Write Strategy field 1 11 86 67 80
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 05
4x Speed OPC power 1B
4x Write Strategy field 1 0E 10 08 09
4x Write Strategy field 2 00 00 00 00
4x Write Strategy field 3 00 00 00 00
4x Speed OPC beta multi-pulse 00
4x Speed OPC power multi-pulse 00
4x Write Strategy field 4 00 00 00 00
4x Write Strategy field 5 00 00 00 00 00 00
4x Write Strategy field 6 00 00 00 00 00
Data area starting sector 30000h
Data area end sector 19CECFh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1*New Mac user*, been PC user 4 life -
Can you look on the center of the disk & see if it has a small logo (RiData) printed on there?
It says: ridata
these 1's have not yet failed for me.
Got them at meritline*New Mac user*, been PC user 4 life -
Yeah the ones that say RiData are awesome ...
It's when they don't have the RiData logo when they become a problem ... -
Bucs,
The 50 pk you just got from meritline dont say that on it???*New Mac user*, been PC user 4 life -
Does anyone know what the difference in the order #'s areOriginally Posted by stphilli
1) ends w/ IW ........ DRD-47-4X-RDIW
2) ends w/ SM ........ DRD-47-4X-RDSM
No , they don't have anything on them.... the Dye looks like the same but for some reason these without the logo will not work past like 3 GBOriginally Posted by Regal
Yea I just read your other post. Take them back 4 a refund bro.Originally Posted by bucsfan97
Meritline gots a 30 day moneyback gurantee.
I'll let every1 know how my NewEgg riteks come along.
I hear they are legit. but some peps says that newegg took for ever the ship. Not me. Next day I got a e-mail saying item was shipped by FED-Ex with a tracking number. They will be here this following Tuesday.
I keep u updated.*New Mac user*, been PC user 4 life -
I always ship with the free shipping from Newegg and I get everything unbelievably quick. (& I live in Fl)
Bucs,
I did some research and as far as I can tell the ones that end in IW are Inkjet Writable (printable). If you don't have a printer capable of printing to dvds you can just buy the other ones as they are cheaper. -
AHHHH.... Sounds like the SM would then stand for (SilverMatte) .... maybe ... or (SilverMettalic) ... Hopefully they stand for Matte ...
Either way I guess would work as long as they have the RiData logo ...
Maybe MANCO can elaberate on the ones he ordered as he stated
I just got a 50 pack of these from Newegg yesterday with my new NEC ND-2500A. They were on sale for $46.50, when I ordered. So far they work great with my drive. They are Ridata brand G04 (confirmed by media code) with purple dye. I haven't had a single bad disk yet. -
OK. I emailed newegg and was told that they were not given the information that the DRD-47-4X-RD-IW were inkjet printable, but they gave me the number to Ritek/RiData. I called them and was told the following...
DRD-47-4X-RD-IW ... IW means Inkjet White, so they are inkjet printable
DRD-47-4X-RDSM ... SM means Silver Matte
Hope this helps people in the future . The Ritek woman said she would contact newegg and "educate" them about the products. I am also going to email newegg, so hopefully they put this information with the product listings soon. -
Newegg.com
Riteks DVD-r 4x Matte Finish
$46.50
Free Shipping
until 4pm PST
http://www.newegg.com/app/ViewProductDesc.asp?description=17-132-315&depa=1-change is absolute- -
All,
As promised. I tested the Ritek go4's from NewEgg and they are the original real deal!!
Says Ridata on it. Silver top coating.
Burned 3 all were a go.
Lov'em
Regal is a happy camper!!*New Mac user*, been PC user 4 life
Reauther dark OEM DVD. Help! Please!
By p71rock in forum Authoring (DVD)Replies: 10Last Post: 26th Jun 2009, 00:46 -
What Model of other Brand->Lite On Model ???
By kevin215 in forum DVD & Blu-ray WritersReplies: 0Last Post: 26th Nov 2008, 06:44 -
Memorex 2.4x DVD+R DL 50pack $19.99 at BestBuy
By dmagic1 in forum MediaReplies: 4Last Post: 3rd Oct 2007, 22:00 -
Are there any methods to get a Ford oem Navigation unit to play dvd video?
By marc32 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 23:11
