My mother has an extensive DVD collection and wouls like to make back-ups of them all. Here is the problem, she really does not know that much about computer. She's got the basics down but that is about it. I am looking at getting her the NEC 2500A and she will be using DVD -R disks(if that matters) I need to find a utility that will allow her to make DVD quality 1:1 backups very easily. Preferably just one program that allows her to de-encrpyt, and make the copy. Not having to deal with multiple programs is a plus. I tried to turn her on to DVD shrink along with a burning prog but that did not work.
Nikolas
Well, it doesn't really get much better/easier than Shrink IMHO.
Latest shrink burns too, if you've got Nero installed...
/Mats -
So let me make sure I have this straight. Buy Nero and install, then install Shrink. Then only use Shrink and it will automatically use Nero? Will it de-encrypt and everything, too?
nero might come with the NEC burner. it did with NEC 1300a. yes to your last concern/question, but you might also want to download DVD Decrypter for ripping also. it too is free.
DVD Decrypter pretty much works like 100% of the time whereas the ripper built-in to DVDShrink works maybe 99% of the time.Originally Posted by nikolasmor
Doesn't sound like much but sometimes people bitch that the ripper in DVDShrink doesn't work with some movies. No such complaints with DVD Decrypter.
- John "FulciLives" Coleman
P.S.
You might want to look into FabDVD which will split a dual layer disc to 2 DVD-R discs so there is no loss in quality."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Best utility to backup drivers?
By alegator in forum ComputerReplies: 2Last Post: 20th Jan 2009, 14:50 -
Extremely easy backup solution.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 19th Nov 2008, 10:14 -
Newbie, advise for easy 1 step backup of dvds
By mbogda in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 13:18 -
Free and easy drive backup/restore software
By pcspeak in forum ComputerReplies: 4Last Post: 7th Jun 2008, 23:10 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 11:05
