If there a DVD player software that will let me view movie frame by frame until I get a desired shot and then capture it? The only way I found was to rip the DVD, convert them to AVI and use VirtualDub to find and capture an image.
Thanks for the help.
Results 1 to 10 of 10
PowerDVD and WinDVD have a snapshot function (it captures the current frame to a file or the clipboard).
I'm sure many other software DVD players also have this feature.
Or you could simply play your DVD on the PC and pause at the frame you want to capture and then press the 'Print Screen' key to capture the screen to the clipboard. Then paste it into your favourite paint program. -
A better idea would be to it pause in PowerDVD and use the 'next frame' key to find where you want and then use the capture/camera function.Originally Posted by bigshotceo
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Thanks. I guess I'll have to pony up and get a copy of PowerDVD. All the DVD softwares I have were the free versions that comes with the DVD I watch or with DVD-ROM. None of them have a frame by frame play and using play and pause to try and hit the certain scene is too much guesswork.
Thanks. -
If you don't want to buy it, you might try hitting PrintScreen, then pasting the saved image (from your clipboard) to your favorite image editor (MS Paint, PhotoImpact, Photoshop, etc.).Originally Posted by tomoki
Printscreen won't work as the video is in overlay and inaccessable to print screen. Rip with DVD decrypotor, load the vob in virtualdubmod,
then click video>copy source frame to clipboard, or snapshot current frame, etc. -
when did they start putting up a fully functional trial? only one I could find (about a month ago) was severly crippled. black and white picture, could only play a few minutes of audio and video, no access to any other functions really. maybe they realized how lowsy of a trial that is.
Capture picture stored on a DVD
By casualdvdmaker in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2010, 08:36 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Combining a single picture with an mp3 to create video file
By mark1111 in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2009, 05:13 -
How do I capture a picture frame from a movie and make it into a picture?
By Hawkredtail in forum Capturing and VCRReplies: 7Last Post: 8th Sep 2007, 19:44 -
Watching multiple streams from a single capture card?
By Drunia in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2007, 18:26
