Is pinnacle studio the only solution for me capturing with my DVC150. I can't find a capture software that supports it.
Scenalyzer Live ( SCLive for short) should work like a charm for you.
or, if you wanted to go the free route. You could just use a program like WinDV... small, free, easy. Then edit the captured avi in whatever program you want. -
If you're not having trouble then you won't gain anything by using a different programme (you are talking about firewire transfer, right?).
Saying that, if you do want a switch, don't want to pay and not worried about a preview then DVIO might be for you.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
no, my DVC150 isn't firewire, it's USB2, so those programs don't works, thanks for tring though
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
