hi
Is it possible to convert divx to avi, if so what kind of tool do I need.
Frank Kuijpers( Netherlands)![]()
A DivX is an avi. AVI only stands for Audio Video Interleave, and only tells where the video and audio is stored in the file. It does not says which codec is beeing used. So a DivX is an avi with the DivX codec. So, what do you want to do with the DivX, change the codec?
Do you mean avi to dvd ?.
If so go to the convert section and read some of the guides that you will find there. -
I want to convert it because my dvd player cant read divxOriginally Posted by larsli
Depending on what your DVD player will accept, you can convert your Divx-Avi to an mpeg for VCD, SVCD or DVD. After conversion you can then author and burn to disk. Look up Avi to VCD, SVCD or DVD in the Guides section for all the details.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 19:24 -
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
DIVX 3 to DIVX5
By munozsblazer in forum Newbie / General discussionsReplies: 13Last Post: 9th Mar 2008, 12:05
