Every time i click on the internet explorer icon i get an error box saying
IEXPLORE.exe has generated errors and will be closed by windows. You will need to restart the program....
I have restarted my pc....Upgraded to IE 6....When I did the upgrade I got a different error message allowing me to try to restart the explorer, send the error to M$ or not to send the error message......So i unistalled IE 6 and back to the original..
I am running W2k with the version of internet explorer that came with it now.....Anyone have any ideas what this error could be? I might have deleated a file by mistake somewhere...Is there some software to help me diagnose this problem and maybe fix it?
Thanks......
Run scandisk or whatever it's called in Win2000 then maybe defrag. The error report doesn't do anything. If you get the Blue screen of death when it shows the erroe it might be a sign that your RAM is dying.
http://www.merijn.org/files/cwshredder.zip run this program. It should clean up the problem.
Rick
x264.exe error
By streetak in forum Blu-ray RippingReplies: 1Last Post: 1st Feb 2009, 12:17 -
error with spumux.exe
By rebel14 in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2008, 18:55 -
iexplore.exe - Application Error
By bluemoss in forum ComputerReplies: 9Last Post: 25th Nov 2007, 07:23 -
IEXPLORE.EXE - Application Error
By dewolf in forum ComputerReplies: 10Last Post: 1st Aug 2007, 18:12 -
iexplore.exe running each time I reboot
By alegator in forum ComputerReplies: 16Last Post: 4th Jul 2007, 10:13
