Results 1 to 12 of 12
  1. I am trying to Capture home videos passing the VCR signal (RCA) into my Camcorder, out from it's DV into a Firewire card.
    I am trying to find a specific Capturing Software that would allow me to apply cropping, deinterlace, select the frame rate and resolution prior to capture to achieve an avi with the best possible resolution at 700mb to be stored on a CD Rom.
    Does anyone know software that would allow me to do this?
    May 2003
    Peterborough, England
    As DV by Firewire is a simple data file transfer and not capturing just copying a file, you can't do it.
  3. I have already done it many times with the freeware; dvapp, WinDV-1.2.3, amcap in the tool section. Also with Vegas Video 3.0 but had to remove the 'Enable DV Device Control' to record the signal. Microsoft movie maker also has that DV Device Control you do not have the option to remove.
    But I am looking for software that allows you to set up everything before you record "apply cropping, deinterlace, select the frame rate and resolution".
    May 2003
    Well, if you've already done it why are you asking?? You can't do it at the same time. DVapp COPIES the DV file from your camcorder to your hard drive. Once there you can do what you like with it with whatever software you like. You can't do anything with a file you don't have and you don't have the DV file until AFTER you have copied it to the hard drive.
    There are plenty of capturing applications that you can set up to crop, deinterlace, etc during capture. You aren't capturing though, you are copying a file. It's a bit like saying you've got a document on a floppy disk in txt format and you want to copy it to you hard drive as Word format. It isn't so you can't.
    Mar 2003
    Uranus
    The impossible just takes a little longer
  6. I am not copying anything...I am using the camcorder DV converters to route my VCRs AV signal into my computer.
    I have already captured with the software stated above, but they don't offer crop, deinterlace, etc during capture.
    Richard_G Wrote; "There are plenty of capturing applications that you can set up to crop, deinterlace, etc during capture."
    Could you suggest a simple capturing application that would allow me to setup crop, deinterlace, etc. as well compression during capture.[/quote]
    May 2003
    Now how can I put this in terms simple enough for you to understand?
    YOU ARE COPYING A DV FILE.
    You are passing an analogue video signal into your DV camcorder. This is then converting on-the-fly the analogue video signal into a DV data stream. You are then using a Firewire connection to COPY that data stream to your computer.
    You are not capturing, the camcorder is. You are COPYING. If you can find a camcorder that can crop, deinterlace, etc, you could do it.
    Is this simple enough now???
    Mar 2003
    Uranus
    There may be an App that can suck up DV and operate on it in realtime
    but I don't know what it is. Mainconcept is supposed to be able to
    encode on the fly , but that may be just for analog capture.
    There's nothing impossible about it with a sufficiently fast computer,
    I just can't recall any that do it.
  9. Member akbor75's Avatar
    Aug 2002
    Netherlands (Europe)
    i think cropping on the fly is a non-issue here, cos you can never know how to save the dv avi file so it would exactly fit on a 700 MB disc.
    i think you sould just save it and crop etc. afterwards.
    this is a normal procedure: capture/save, edit, burn.
    Music was my first love, and it will be my last
  10. Yeah ok...Technically I am copying the data converted by the DV Converters of the cam to my hardrive. But in every program I am using, the program command that is available to copy is called capture!!!
    But all of that is beside the point...forget it. ok. I just would like to know if there is a simple program that would allow me to select a compression and filters when capturing. Thats all.
    I do not want uncompressed data that will take up my whole drive, and if possable do all the set up prior so when finished there is no additional steps. Like making a dvd into an avi with Vidomi, I rip once, than use my vidomi template to convert it to a 700mb cropped & deinterlaced file.
    That simple...but for capturing its not. So if anyone knew of a simple program like Vidomi, but for capturing please let me know.
    Mar 2003
    Uranus
    DV is only 13 gig/hour compared to 110 for uncompressed RGB
    Surely you have at least an 80 gig drive
  12. Member akbor75's Avatar
    Aug 2002
    if you don't have to edit capture as mpeg2 may save time (and disk space). i think every program with dvd burn capabilities can do that. i know pinnacle studio can.
