Okay. This might be an obvious question, but, I have an .avi on a cd-rom. I use Windows Explorer to copy the file to my hard drive, however, the file quits after approximately 60% and tells me "cannot copy file - invalid MS DOS operation". On another occasion, it told me I had a CRC error. I can watch the entire .avi on media player, so I can't figure out why I can't just copy it to my hard drive.
try opening the avi through virtualdub, then do a direct stream copy (video/audio) save to a location on your harddrive.
Thanks for the quick reply! I tried that before, and I just tried it again with the settings you suggested. At frame 90942, I get the error message, "Error streaming AVI : Data error (cyclic redundancy check). Any ideas? I also tried a few avi fixit programs, but they don't save to a new file, they try to fix the original on the cd, which gives me the error that it is a read only file.
i think your disc is bad. you might try cleaning it.. if its flawless you either have a bad burn or a defective disc.
I think you're right, bud. Thanks for your time, I guess I'll move on to something else.
Weird .264 file and conversion issues
By agni451 in forum Video ConversionReplies: 3Last Post: 28th May 2010, 07:56 -
Really weird video file problem
By alexdogg in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2010, 12:27 -
Really weird pixellation in video file.
By teapot in forum Newbie / General discussionsReplies: 15Last Post: 7th Dec 2008, 12:42 -
Weird wave/MP3 file
By AlanHK in forum AudioReplies: 2Last Post: 20th Nov 2008, 00:33 -
Rotated .MOV file, weird behaviour
By Leo48 in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2008, 17:18
