I am currently a subscriber to cable modem through adelphia, and that service is fantastic. I don't pay for the cable tv, but apparently they just send it anyways along with the signal, it must cost more for them to disable it than to just keep sending it. But the quality sucks, on cartoons, especially futurama, there are little black lines leading in from the outlines into the shading colors on screen and in my captures.
Who the hell do I complain to?
Could be a signal issue, either try a booster OR put a splitter ont he line before it hooks to your tv. Even though you don't want to split it if the signal is to weak or strong it can sometimes cause picture issues. If that doesn't do it then just call the cable company and complain. Of course its hard to complain about something your getting for free.
A friend of mine had the same problem. He uses a splitter for the connection and enjoys free cable.
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 13:59 -
TOSHIBA D-R7. Problem with quality of coax cable.
By caddyfleet in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Feb 2010, 20:01 -
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2010, 00:23 -
How am I getting these cable channels free?
By vid83 in forum Off topicReplies: 11Last Post: 20th Mar 2009, 18:43 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 11:46
