I thought all DVDs were progressive, and were just interlaced on normal tvs...but then today I read a post on another forum & the person said most DVDs are interlaced...and progressive DVD players de-interlace them.
Is this so?
And if it is, then when I encode to mpeg2, should I be doing it as interlaced or progressive?
Every DVD is different. It depends on how they shot the movie. If they used Digital cameras, then there's a good chance that the footage is interlaced. If the only used film, then there's a good chance that it's progressive.
It all depends on your source. If it's interlaced, then encode interlaced. If it's progressive, then encode progressive. You have to determine what the source is.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Quoting my bible:
Technically, DVD-Video can only be stored in interlaced format. Signals from standard video cameras are already in interlaced format. Film, which is inherently progressive, is encoded into MPEG-2 as paired fields. Even though the encoding is field-based, the frame-based nature of the source can be preserved. This allows progressive-scan players to put Humpty Dumpty back together again. -
sacajaweeda: I'll have to pull out my decoder book, to de-crypt your bible quote :P
and how do I know if the source is progressive or interlaced? I tried looking, but I can't find any program that gives that particular info. -
Well you could check the frame rates with something like VirtualDub. If your frame rate is 23.976fps, it's progressive.
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 10:22 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 17:41 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 12:01 -
DVD encoding issuses w/ progressive fames plays back as interlaced. SOLVED!
By ty1er in forum DVD RippingReplies: 1Last Post: 19th Aug 2008, 09:34 -
30FPS Progressive to PAL Interlaced? (DSC MJPEG AVI to DVD)
By ezekiel42 in forum Video ConversionReplies: 7Last Post: 8th Jul 2007, 23:53
