I have this movie that has a dual audio stream. Its encoded in Divx5, the first stream is AC3, and the second is mp3. id like to rip the second stream so i can reencode the video with that as its primary stream. But i cant seem to find any sort of guide or program that can do that, which kind of suprises me. Im pretty sure this could be a fairly simple procedure, its just not a be subject. It's just driving me nuts, and id like to know how to fix this. please, any help is appreciated.
Correct me if im wrong, but i think Nandub can only encode dual audio avi's. To tell the truth, i used this b4 i posted, but i just couldnt get it to extract the 2nd audio track. i tried setting the 1st audio track to 'No Audio' and the 2nd to 'Direct Stream Copy' from the source, but that didnt work either. I'm lost, how could something seem so simple, and yet be so complex.
Easy peeze that is. virtualdubmod
goto styreams>view sreams
there you can cick it and demux.
Dont reencode, just mux them back together again. -
wow! thanks. i knew this wouldnt be THAT hard. jus couldnt find the right tool and stuff. This virtualdubmod seems to be alot better than the original. Gotta give it props =P. Thanks alot, apperciate it
virtualdubmod is l33t, and many features more than the original, including mpeg 2 import support, subtitiles, multiple audio tracks. Good times.
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07
