Hi folks,
I am only able to burn about an hour worth of mpeg files I have to DVD. What am I doing wrong. I was under the impression that 4.3 GIG DVDR would be able to hold close to twice, 155 min.
If you need more details to help me out let me know.
Thanks.
It all comes down to bitrate. You can put more video on the DVD by using a reencoder, or transcoder to reduce the bitrate, and therefore reducing the amount of memory required to hold each second/minute/hour of video. At max bitrate (9000 or so) you can only fit about an hour, depending on the audio format. Tmpgenc is an encoder you could try, DVD Shrink is a transcoder that you could try.
Capture Short Video Clips From 1.5 Hour DVD
By Grassman in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2012, 01:52 -
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 14:35 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38 -
Capture, Burn, Distribue in same Hour
By hap123 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 01:18
