Before I ask my question, let me explain what I'm trying to do. I'm trying to make a compilation DVD of an actor. Using Ulead VideoStudio 7, I created a title screen (of the actor's name) that I want to appear at the beginning of the DVD and then I want it to go right into the scenes I have already pulled. i.e. I just want it to stick the DVD in the player and have it play seamlessly between the title screen and the acting scenes. Ulead spit out the title screen as an mpg file. The scenes I need to burn are VOB files. How can I burn these files to a DVD so that it will play the way I described above? Thanks in advance for your help.
Sounds like you're using files from other DVD's? If so you need to demux each one. Then you can set them up as tracks in Ulead (I've never used this app but can assume it works like most?). Have your menu set to timeout and endjump to track 1 - track 1 endjump to 2 and so on. This should be very simple once you have converted your VOB files to mpg2.
Hope I'm not misunderstanding your question and stating the obvious here.
NJF
Mass conversion to multiple file formats
By Haopengyou in forum AudioReplies: 8Last Post: 11th Aug 2011, 02:35 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Converting multiple formats to WMV
By StrangeSolutions in forum Video ConversionReplies: 5Last Post: 9th Dec 2008, 19:43 -
editing with multiple formats
By abadifilms in forum MacReplies: 1Last Post: 15th Sep 2008, 13:59 -
Plaing multiple formats at the same time.
By TheWiz01 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 12:36
