  1. I am having the following messages pop up when i try to burn a dvd...
    first it says: NTSC Requires at least one AC3 or PCM audio track for every title set. Do you want to continue the build with all MPEG audio?
    and i click "yes"
    than about 5 mins into the burn... this message pops up:
    Sorry. an abnormal condition has been detected. Before quitting you have one chance to save your project (don't use the same name as the original).
    CAN ANYONE HELP ME WITH THIS?
  2. This has been addressed at length in the Adobe forums. Check there. It should be an easily-solved problem. If I could remember the details I'd be more than happy to help...
