some1 told me that i can put a whole bunch of vcd on a dvd and it will work. they told me to go into ner and select dvd-iso and add all my files. so i did and i fitted about 6 vcd on it. when it finish burning my dvd i stick it in both of my dvd (mintek dvd-2580 and Norcent DP300) and it didn't work. is there any other way about doing this???
your player must support "dvdmpegiso", play any mpg file on a dvd without any authoring like select files from a file browser.
if you want the vcd files to work on most players you must reauthor to a dvd video, http://www.lordsmurf.com/convert/vcdtodvd/vcdtodvd.htm
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 16:23 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
