I've been able to make a menu but I'm not sure How to get both the menu and the movie on to cd. I can burn the bin to the cd but then how do I get the movie on it
B
Results 1 to 11 of 11
If you made a complete menu including text then you have to use EZCD. If it is a bitmap (bmp, jpg, gif) or animation/video (avi or mov) then you have to convert it to mpg. With EZCD, you can have multiple menus and startup videos.
If it is just a background image, then you can use Nero. Unfortunately, Nero doesn't support (that I can tell) animated menus. Nero also forces the text to be one of several fixed styles with non-removable header and/or footer lines. -
For real VCD authoring flexibility, you should get either VCDImager, VCD Toolkit, or VideoPack4.
Regards.
Michael Tam
w: Morsels of Evidence -
What I did was make a menu with TSCV and made the bin and cue file. I'm not sure How to get that and the movie I converted with tmpg to svcd burned together on the CD I have VCD imager at home I'll have to take a look at it if its possible to edit with it
Not sure if I need to convert the bin and cue before I burn it or something ?
<font size=-1>[ This Message was edited by: Bkbrawl on 2001-10-19 16:02:35 ]</font> -
If your using TSCV you add the menu, MPEG/s, chapters, intro/extro MPEGs, etc. then make a bin/cue with all the data and burn it.
Take a look at:
http://www.personal.psu.edu/users/r/d/rdm186/ -
Yes, that is the guide "Martini's" that I followed and its a good one too I might add. I made a starting menu and a chapter index going by the still menu guide. Nowhere does it say to add in where your video mpg is, so now I have a bin and a cue of the menus and also a mpg of the movie and am trying to find out how to combine them on a cd. I can use fireburner to burn the bin and cue but then how do I get the movie on there? Do I need another program or Is there a step I'm missing? Maybe the movie supposed to be included in the bin and cue? Anyone that can give me a clue please post, Ive been trying to figure out all these programs all week and have only made 1 cd so far. hehe I'll be searching the forums again like last night =P
B
<font size=-1>[ This Message was edited by: Bkbrawl on 2001-10-19 17:17:52 ]</font> -
Doh, I think I figured it out. I'm supposed to be entering the Movie under the chapter index before making the bin
Thanks for the help
B -
Well the problem now is when the sound loops, the still menu expands in size and shrinks back after the sound starts. Is there something that I can do about that?
im happy you figured that you
yeah, my suggesiton is to use blank audio
i never had that problem so i dont know, try no audio or blank audio
(you can encode your mpv from tscv in tmpgenc as a "system (video only)" file
lemme know
martini
Actually, I was able to fix that as well after looking on ttools website. What I did was increase loop wait time from 1 to 1.5 Now I just have to get these damn screen sizes right I've tried 704 X 480 and 352 X 240 with the menus encoded in svcd and vcd not coming out right though :/
are you encoding pal or ntsc?
lemme know
looping video for menu
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 23rd May 2009, 07:03 -
burnning dvd
By brenjim in forum Video ConversionReplies: 14Last Post: 2nd Mar 2009, 12:44 -
Burnning iso to DL disc
By leda in forum DVD RippingReplies: 8Last Post: 25th Apr 2008, 18:20 -
Plextor 810SA Burnning DVD 9 Disc
By wagswvu in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 10:33 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 01:23
