First let me give you the specs on my setup. I have a Dell Pentium 4 , 1.80 GHz, with 128MB RAM , running Win XP with a Soundmax Intergrated Digital Audio card. I have an Office Essentials IEEE 1394 PCI Card, and my camera is a JVC GR-DV500U. Software consists of Ulead Video Studio 5, Image Mixer V1.1, MovieWow, Virtual Dub, and the complimentary Windows MovieMaker.
My video quality still seems quite poor and is not much of an improvement over my old analog camera. (dissapointed) I thought that by going to DV it would be much better. Any tips, recommendations, etc from those in the know. Would be appreciated.
Peter
If the input is Firewire and if the video you produced looks worse than the video source, then the only problem could be the settings you're using to produce the final video. What are your settings? What format are you outputting to?Originally Posted by Peter Howells
Well, it sounds like you haven't created any files from the captured video yet. Just remember that when you do the video capture from your camcorder that there will be interlacing in the video which might make the video look worse. That's normal and won't be visible if you burn the video to DVD and play it on a TV. If you're planning on capturing then converting to a computer/web video format (a format you're intending to play primarily on your computer), make sure you deinterlace the video (to remove those lines). Check out the Guides to the left.Originally Posted by Peter Howells
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 02:06 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
video quality to movie quality
By pitta1990 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2007, 00:31
