    Jan 2004
    California
    Just put in my copy of Remember the Titans and it is 4,880 MBs. Need to remove some things and was unsure what to get rid of. Have done this before, removed the wrong files and the disc didn't play back.
    I have seen the DVD Shrink help page that explains this, but some of the subtitles and other files it says to remove aren't present here. With Remember the Titans, the Audio files are as follows:
    1. DTS 6-ch English - 697 MB
    2. AC3 6-ch English - 416 MB
    3. AC3 6-ch French - 355 MB
    4. AC3 2-ch English - 178 MB
    5. AC3 2-ch English - 178 MB
    Obviously need to get to 4,464. What needs to be removed to get me there. Thanks in advance for the help.
    CB
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    I would keep this one only
    then i would test it out before i burnt it to a DVD
    1 is DTS and my system cant play it, yours might though
    3 is french and i cant understand it, you might
    4 and 5 look like the directors comments or something else
    Dec 2003
    Idaho, USA
    Kill #3 for sure, unless you are French. At this point check what the compression is in Shrink, I think you will probably be close enough to make a pretty great quality copy. Also be sure to run deep analysis before you burn and all should come out nice. (Once loaded into Shrink, uncheck the things you don't want like the french audio, then click on backup, then check deep analysis and you are off and running) If you have Nero and have it configured to work with Shrink, at this point, take your original disk out and put a blank DVDR or DVDRW if you want to test it first, then turn it loose and enjoy a tv show or what ever while it burns.
    Dar
