Hi All,
I am a newbie and I'm still learning. I used a product called Hades to decode my DVD, then I used ffmpegx to size it correctly. Then I added the contents of VIDEO_TS to Toast but Toast said it was still 7.1 Gigs... so I previewed the .vob file that I thought was the main feature in ffmpegx. On my Mac it played the movie correctly with the right audio track. However, once I burned the DVD in Toast and played the DVD in my player, the video was fine, but it had only the commentary track as audio... How can I be sure to use the correct .vob to get the right audio if the preview plays something different than the finished DVD in terms of audio tracks?
Thanks for your help in advance!
Guest
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 12:57 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Commentary track
By AlanHK in forum AudioReplies: 10Last Post: 6th Nov 2008, 03:47 -
iDVD 6 - No audio track on burned DVD?
By KWagner in forum MacReplies: 1Last Post: 12th Sep 2007, 11:31 -
Add a commentary track to A DVD
By R3bel in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 09:42
