Hello,
Sorry if this is the wrong room, or an over-kill topic, but I have tried many things that are in various posts and nothing seems to work.
Does anyone have a good way of burning MP3's to a DVD-R disk that will play on a standalone player that DOES NOT support DVDMP3's?? I have heard of converting the MP3's to AC3's with BeSweet or attaching video files to "trick" the player that it's actually a DVD video; but I have not seen a clear guide for making these playback. Here are my specs:
AMD Athlon XP2700 2.13 GHz
WinXP Pro SP1
DVD Burner: Pioneer DVR-105
Players Used: Panasonic S35S and Toshiba SD-3950 (Neither one worked)
I did burn nearly 1GB of MP3's onto a DVD-R using Nero DVD-ROM (UDF/ISO) mode and everything will playback fine on my PC, but NOT my DVD player or anything else![]()
Any How-To's out there??
Thanks,
Garrett
Hello mate.
https://www.videohelp.com/forum/viewtopic.php?t=200466
Have a look at that thread, might be some info there to point you in the right direction.
good luck!!"Pull your tongue out of my ar$e hole Gary...dogs do that. Your not a dog are you Gary?"
"Err no...."
"But you do have all the characteristics of a dog Gary...all except loyalty."
How to make a region free disk
By aussierobbe in forum Newbie / General discussionsReplies: 5Last Post: 21st Apr 2011, 23:25 -
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 04:26 -
DVD software to make simple divx data disk
By gthorley in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 13:28 -
X.4.11 "Make sure that your startup disk has no spaces or special char
By etyrnal in forum ffmpegX general discussionReplies: 4Last Post: 20th Jan 2008, 23:23 -
How to make DVD recorder disk playable on TV with all scenes intact?
By Stabes in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 14:02
