try playing burned princo's after 8 months
in my case its hit & miss,only about 50% of them
work now.the success rate which i stated above is not
for writing but for reading afterwards.if you are writing
important data/video to princo media be prepared to
lose it in the near future.i've been testing dvdr media for
over 12 months now so this is reliable advice, i've chosen
RITEK GO4.be warned....princo at your own risk!!!!!!!!!!!
Results 31 to 33 of 33
Hey guys, I got kind of lost in the links above. So can someone tell me where I can get a good deal on 4x Ritek printable DVDs? Many thanks!
Edit: I live in the US, if that matters. -
I have had good luck with Princo 4X media, though I would consider it to be of lesser quality then Ritek. One thing I have found out about Princo, is that they are very picky about drives. The NEC-ND1300A is one example. They say 1.08 firmware works with the Princo media, but my results have been mixed. Anything less the 1.08, I wouldn't use Princo. Also the TDK indiDVD has not liked the Princo discs. I have not had any issues with my Pioneer 106D.
I like Prodisc media best right now. Good quality for the price. I get mine from: http://www.emediadepot.com/dvdr.html
Need assistance with Higher Quality Stream
By js1974 in forum Video Streaming DownloadingReplies: 0Last Post: 30th Aug 2010, 20:09 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33 -
converting it to higher quality
By JTG in forum Video ConversionReplies: 6Last Post: 27th Apr 2009, 18:22 -
which scenario gives a higher quality video?
By graysky in forum DVD RippingReplies: 19Last Post: 3rd Sep 2007, 11:40
