I watched the sticky note video on the differences between pressed and burned discs. I understand how the laser burn marks act as the pits. Non-rewritables I can grasp, but how does the burned dye get replaced on RW's when they are altered,erased,etc.?
GuestGuest
It’s my understanding that the Laser in the burner is turned on at a lower temp and ran over the entire surface of the RW media. This causes the material on the surface to be de-pitted and ready for the next burn, which uses the higher temperature.
Samsung c500 reset ***HELP***
By Samsungc500 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Nov 2011, 19:51 -
Hard reset for BDP3000
By alexh110 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Oct 2011, 10:37 -
vsRip will not reset timing
By kenryuakuma in forum SubtitleReplies: 3Last Post: 26th Sep 2011, 18:45 -
How do I reset the code?
By deltarory in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2010, 05:35 -
Magnavox mdv430 How to reset
By soluble in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:27
