hi im new to this and me and my mates are making a video and we want to upload it to the computer to edit it right but we cant use firewire or anything so we have to use tv capture but will be capturing from a VHS cause we have to record it from the cam. onto a tape then capture but i dont know which capture card to get can anyone recommend any ?? infact i dont know anything bout capture cards so any information is helpful.
I f you have no intention of ever watching TV on your computer I would stay away from TV tuner/capture cards and go with a straight analog capture device (they usually have more bandwidth). There are a number of them and I am only familiar with one (lower priced one). I have the Pinnacle DC10+ and it cost less than 50 US dollars. They go up in price from there, but I'm happy with it. Currently I don't even use that card anymore to capture analog. My digital camcorder has an option called analog pass through. You can connect the analog device (VCR, camcorder, DVD player,etc.) into the jacks on the digital camcorder and the digital camcorder plugs into the firewire port of the PC. If you have a digital camcorder or can borrow one from a friend that might be the best solution (providing it has analog pass through).
What is the source of the video you wish to edit? Is it from VHS? I couldn't tell from your original post. If it is a VHS or analog source, then you will need a capture card with analog input. These can either be internal PCI cards or external via USB.
Internal Capture Card
External Capture Card
Good Luck,
Garrett -
Why do you have to record it to VHS before you can capture it? If you can output it to a VCR, shouldn't you be able to output it directly to the capture device?Originally Posted by Omekou-Chi
thanx for the help people.
i dont think i can output it directly to the capture device im not sure but now i think me and my mates are gonna use mini DVD camcorders instead so we can load it using firewire.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 19:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 08:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 21:53 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 21:26
