ibm has a file on their public ftp of ibm recordnow max 6.5(newest).. its the same as the retail one, it just has an ibm badge on it.
i think you need to have an older version of ibm recordnow max on your computer to install it.. its kind of like an upgrade.. but it does a full install.
the procedure for getting it to install on your computer this;
Yes it would. Removed the text about how to do it as well. / Moderator flaystus
Results 1 to 10 of 10
removed all comments after vitualis' reply
I would still consider that to be warez.
I also consider IBM to be rather lax in their security as well.
Regards.Michael Tam
w: Morsels of Evidence -
I would consider that a HUGE understatement.Originally Posted by vitualis
Technically you are using a crack, just one that you made yourself instead of downloading.
I find it funny though that IBM is stupid enough to leave a copy on their public FTP. -
so opening an ini file, deleting 2 lines of text and saving it is considered a crack?Originally Posted by pacmania_2001
Yeah, like I said if its an exe, batch file, or manually done your editing a program in such as way as to install it without paying for the application.
Funny as it is that IBM did that its really still warez. -
If it was the RecordNow version 6.5.3 from 11/19/2003, it wasn't exactly hard to find. Only took about 5 minutes and a file called all.... located on the server. Nice ftp, I'm glad they went to so much trouble to make it easy to find things, wish Epson did the same
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I suppose this would be warez because you are getting the full version, but there are others who could argue the other side. It reminds me of a dedate with others I had about No-CD cracks for games. I said that the crack themselves were not warez because they had a great application in a legal way, it becomes a pain to insert a CD for every game you own sometimes, but I suppose everyone has a side of a story.
Sources for high-end VCRs considered
By sanlyn in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2012, 09:57 -
Whats considered HD/Blueray resolution?
By shagratt71 in forum Newbie / General discussionsReplies: 12Last Post: 11th Jan 2012, 07:13 -
Are cookies considered malware?
By alegator in forum ComputerReplies: 6Last Post: 8th Jul 2009, 17:24 -
Not WAREZ . . . I think.
By Karyu in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2007, 12:34
