i've been doing dvd-vcd convrsion for quite a while now but have got me a dvdburner so i consider myself a newbie. what i'm stuck on is this: how do i back up my vcd's onto a dvdr? i tried with nero but it said i couldn't write this type of file to this media. thanx in advance
Rip the vcds with Isobuster high-light the Mpegav an in the right hand window high-light the film file (if it was made with Nero it will prob be calld somthing like avseqo1.dat) right click on it and goto extract but filter onlym2f2mpg frames
an save the file were ever you want it but remeber when renaming it to add the .mpg file prefix do the same with the second disk then fire up tmpge and goto mpge tools goto merge & cut load in your two file you will then get one mpge file you can then use TMPGE DVD to maske a dvd ready file(by the way you can get a couple of films onto the one dvd this way)
Thanks to Lord smurf for this as I think it was one of his tut I first learned to do this from(but I cant find the link to it its here somewhere(dvdrhelp)
good luck mate.
Found the tut on the lord smurfs page maby one of the mods will give you the link as I don't know if I can post a link to anothe site here."The full area of ignorance is not mapped. We are at present only exploring the fringes."
JD Bernal -
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
