i wanted to know if there is a cd i can burn that can convert PAL-TO-NTSC ... my panasonic dvd player doesnt support region-free dvds ...
is there such a thing?
thanks...
Duhh, I must be having an off day or something. I havn't got a CLUE what you are asking
1. Region settings have nothing to do with the TV system a Movie is designed to play on.
2. Most European players (TV's) will play both formats. (Not as common in the US I believe)
If you can not play the film because your player is region locked you can look try to find a region free hack for your player or you can make a backup of your DVD, this usually (depending on the copying s/w) will make you a region free version.
If you absolutly must reencode to NTSC there are guides to do it. Its not that easy and can produce poor results. The dedicated hardware used by the studios is way beyond our budget
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
