i've been using the PANASONIC AY-DVM63PQ, professional mini-dv tapes w/my Sony trv-22 & basically sticking to that since it's recommended to keep using the same brand.
however, i've been wondering what really is the diff b/t professional tapes & consumer ones. i didn't see that much of a diff b/t the sony ones i started off using & the panasonic ones that i am using now.
actually the colors don't seem as vibrant since i started using the panasonic ones. could this be b/c of the tape? maybe it's just the conditions of where i was shooting at. dunno.
anyhow, i don't wanna waste my $ on professional ones if there isn't that much of a diff ya know.
any input on this would be much appreciated, thanks.
lots of the video quality comes from the video camera. I think the main bottle neck for video quality is the camera. if the professional tape is used on a consumer level camera, the quality of the video wont be much difference than with a consumer level tape. unless you use a professional level dv cam, i dont think you would be making full use of your pro level tapes. usually using the same brand of tape with the same brand cam produces better quality.
jpvideo is right -- not a lot of diff. on the tapes. Pro tapes would have a better base in some cases and sometimes better internal parts - now days the metal oxide layers are about the same ...
... though its a well known fact that Sony DV tapes dont work well in JVC DV pro decks.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
for those of u who have a trv-22 as well, what brands have worked best for you?
also, if i switch from a professional tape as i have been using, to a consumer one & just stick with that brand from now on, will that change cause problems? or do the problems only occur when brands are being changed on a constant basis?
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Please recommend a professional video transfer service (tapes to harddrive)
By DaveP56 in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2011, 17:19 -
HD Mini DV tapes to Digital
By oriopn5150 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 20:26 -
Consumer vs Professional MiniDv Tapes
By ettin in forum MediaReplies: 1Last Post: 14th Mar 2008, 22:01 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
