Hi,
Does anyone knows whether it is possible to encode the audio track from a VIDEO_TS folder to a single MP3 file, whitout encoding the movie (I just want the audio track).
I tried selecting "passthrough (ffmpeg)", disabling "encode video" and selecting MP3 in audio, but the terminal sends an error "VIDEO_TS format not recognized".
Howeevr it works fine if I encode the video in XVID too...
Any idea ?
Thanks !
europazeusGuest
You can use 0SEx to extract elementary streams (so you will obtain the audio track as a separate file), then convert it to mp3 (eg by using mp3 preset in ffmpegX).
Bump. 0SEx only seems to open mounted DVDs, not video_ts files. I'm having the same problem with ffmpegx that this fellow is. I only have access to a mac, so I can't use windows options. Am I screwed?
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 13:05 -
question about how to extract mp3 audio from DVD
By jimdagys in forum AudioReplies: 5Last Post: 17th Apr 2008, 11:19 -
DVD Audio from mp3
By TechJD in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 14:12 -
Burning mp3 audio files onto a DVD
By DKRoff in forum AudioReplies: 4Last Post: 23rd Oct 2007, 06:05
