please help?i have used the guide in dvd ripping to rip my dvd using smartripper,dvd2avi,tmpgenc+vfapi plugin,nero.
when i come to burn the vcd through nero it says mpeg file is unsuitable for such a disc(vcd v2.0 cdi player)??
thanx 4 any help,Andy.
What version of Nero, and did you use standard VCD bitrate?? did Nero say "detected stream is not VCD format, yadda yadda yah, reencode, turn off, canca" something to that effect?
Yes Nero is real pciky about having standard spec VCD, so your VCD must not be standard spec...at this point either "click, turn off stand compliance check" when it ask you that question as far what you want to do....but from there, when you go to "start new VCD", look on the initial screen, and you will see a check/tick mark by a line that says "check for standard compliance" or something to that effect....you can uncheck/untick that and that prompt should no longer come up when you get ready to burn.
hi m8 thanx for the info so far but i've now done that and burnt it to cd ........the pictures great but theres now no sound????????????arghhhhhh
LOL, sorry to hear that, how did you process your audio?? and maybe I can help there too as well
hi,i used this exact guide:
http://www.vcdhelper.com/dvdtovcd.htm
ripped the dvd with smartripper then dvd2avi
and then inserted into tmpgenc the video.d2v and the audio file .........then i put this into nero 5.5.4.0 and it came up with a great vid after i turned the compliance thingy off but no audio.........i cant figure out why its done this though as i've followed the guide on this site word for word,it must be someting too do with my error (vcd v2.0)???? thats all it seems to have thrown up wrong to me?thanx again Kdiddy
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 20:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 19:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 18:34
