I keep getting this message popping up and asking "A runtime error has occurred, do you want to debug?" Then when I click yes it will not allow me to debug (whatever debug means?). Meanwhile since this has started happening my computer has lost a good 40-50% of its speed while browsing the net, downloading programs, opening and sending emails. COULD SOMEONE PLEASE LEND SOME ADVICE ON WHAT I CAN DO TO CORRECT THIS SITUATION, I WOULD REALLY APPRECIATE IT. THANK YOU VERY MUCH.![]()
Thank You,
GolfNut -
Open Internet explorer
select tools
internet options
advanced
check Disable debugging
See if that works. -
808smokey thanks for the advice, I will give that a try.
Thank You,
GolfNut
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
