Hello people, just want to ask a few ickle questions and u can c how slow i am for yourselves!!
OK i have used a program to convert avi files into mpg files but not sure what to do with them now, basically i want to be able to put avi files onto a dvd so i can watch them on my dvd player!! I dont know what software to use and im not completely computer illierate but i think im confusing myself by trying to read everything.......
Urm what do you need to know ...
Any ideas would be greatly appriciated x![]()
Results 1 to 9 of 9
What's an ' ickle'?
NO - basically they need to be in MPEG as you previously stated you have. Then they need to be "authored" into the DVD structure.....basically i want to be able to put avi files onto a dvd so i can watch them on my dvd player!...
Unless of course you have a DVD player that reads MPEG then why bother.
Authouring : https://www.videohelp.com/guides.php?howtoselect=3;6 -
Everyone has their own method and there have been a few posts/polls regarding what people use. So be prepared for many different responses.
I myself just take the avi files and convert them to dvd complient mpeg file in tmpge, use the wizard and select DVD, then just browse the file you want to convert and follow the instructions. There are other things you can do in this wizard like starting point or using filters and all, but just stick with the basics and dont bother with these as yet. Laod your file and keep clicking next until it starts to encode. About an hour later, depending on ur PC, you'll have your files ready. Next I use dvd author and I load the file i just converted (it will be an mv file) and let it convert to dvd files(vobs). You can even burn the dvd after it is finished. It will ask you if you want to do this, but I would hold off until I preview it in power dvd first, if it looks right, then burn it.
OH YEAH, USE A DVD-RW. -
ickle = small/tiny!
wow can i say thank you for your speedy responses i will take on all advise and learn from here! :P
thanks again x -
go to tools on the left and do a search, that will take you to the site to download.
Hi kate1981,
See this link:
https://www.videohelp.com/forum/viewtopic.php?p=725433#725433
...for the steps I take to go from DV cam (transferred to DV AVI on my PC) to DVD disk with menus and good quality. I don't claim it's the best way or the right way as there's loads of ways and loads of different tools. But it will give you a good insight into what you need to do, typical tools and settings.
If your aiming to get over (approx.) 100mins onto a DVD, you'll either need to reduce the quality (by reducing the bitrate, see below) or keep the quality and split the output on more than 1 disc.
A bitrate calculator is used to tell you what bitrate you need to use either:
1. As a max for Constant Bitrate encoding - CBR, or
2. As the average for Variable Bitrate encoding - VBR (as I use in the link above).
A good one is the DVDRHelp Bitrate Calculator, but there are others in the Tools section.
Hope that helps. Good luck - It's a minefield and seems hellish at first, but the effort is worth the reward and the satisfaction.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
HD TV Best Deal for 40-50 in HD TV? I have no clue about TV's
By sandman423 in forum Newbie / General discussionsReplies: 17Last Post: 14th Jan 2012, 23:33 -
Clue me in on deinterlacing video from camcorder
By primus_fan2001 in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2010, 17:31 -
No clue why one video is playing and the other dont
By jce353 in forum Newbie / General discussionsReplies: 5Last Post: 26th Jun 2008, 18:18 -
15 Difrent softwares and still no Clue!
By minimints in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2008, 00:39 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 21:10
:P
